[gdal-dev] Attempting to access an ArcGIS REST API through a WMS format minidriver
Dmitry Baryshnikov bishop.dev at gmail.com
Tue Aug 11 01:14:32 PDT 2015
Hi Stefan,
The QMS (QuickMapServices) plugin uses the GDAL AGS capability to work
with ArcGIS MapServe, so if gdal works with you ImageService, th QMS
will work too.
Best regards,
     Dmitry
11.08.2015 10:15, Stefan Keller пишет:
> Dmitry
> Oh, thanks.
> Do you know BTW somebody from QuickMapServices (which also seems to
> support some of ArcGIS REST API for QGIS)?
> I'd like to know if this plugin only works with ArcGIS MapServer (or
> also ImageService of static MapService/WMS) and I'd like configure an
> own MapServer (and it shows nothing).
> Yours, Stefan
> 2015-08-10 18:55 GMT+02:00 Dmitry Baryshnikov <bishop.dev at gmail.com>:
>> Hi Stefan,
>> The ArcGIS REST API was introduced in GDAL 2.0 (see
>> http://gdal.org/frmt_wms.html). What is you GDAL version?
>> Best regards,
>>      Dmitry
>> 10.08.2015 19:02, Stefan Keller пишет:
>> Hi Dmitry
>> When testing your example I get "No mini-driver registered for 'AGS'.":
>>> gdal_translate -of PNG ags.xml ags_test.png --config CPL_DEBUG ON
>> ERROR 1: GDALWMS: No mini-driver registered for 'AGS'.
>> GDALOpen failed - 1
>> Do you know if this AGS mini-driver code is made publicly available i.e.
>> being pushed to the GDAL source/trunk?
>> Yours, Stefan
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
