[gdal-dev] (no subject)
user gdal
userofgdal at gmail.com
Thu Aug 20 01:39:28 PDT 2015
Dear Dr. Brad, Thanks for your kind and prompt reply. Below are my
answers/clarifications.
On Wed, 19 Aug 2015 04:01:32 PM user gdal wrote:
> Dear friends,
> I have to programmatically clip (using Visual C++) with
> GDALWarp. I proceeded like this:
> GDALDataset *outimg;
> outimg->(GDALDataset *) GDALOpen(filename, GA_Update);
> /* I also tried, instead of the above, outimg=driver->Create(filename,
> NewCol, NewRow, Band, DataType, NULL); */
> GDALWarpOptions *WO=GDALCreateWarpOptions( );
> if(WO)
> WO->hSrcDS=inimg; WO->nBandCount=Band;
What is inimg?
Ans. The bigger input image from which I want to draw subset (i.e., clip)
with the help of a vector layer myshp. It' (inimg) is of type GDALDataset
*. In the declaration of variables, it would appear as GDALDataset *inimg
Also, in WO->hCutline (pl. see below), I am passing myshp (which has
strictly polygon topology), of the type OGRLayer * (i.e., OGRLayer *myshp).
Of course the shape file and inimg have the same projection.
What (exactly) are you passing as filename?
Ans. char *filename (such as e:\sub\subimage.img. There are no other
characters in the 'filename')
Can you try posting an actual, compilable example?
Ans. There is a GUI from which I extract parameters which can give us a lot
of inconvenience. The program compiles without 'abusing' me. What I am
getting is a run time (or debug time) error.
GDALDataset *inimg, *outimg;
NewCol, NewRow, Band, DataType, NULL); NewCol and NewRow, have values of
the range 30 each */
if(WO)
// In a sample image I wish to use, Band =3, checked
WO->hDstDS=(GDALDatasetH)(outimg); WO->hCutline=myshp;
WO->panSrcBands=(int *) CPLMalloc(sizeof(int)*Band);
WO->panSrcBands[0]=Band;
WO->panDstBands=(int *) CPLMalloc(sizeof(int)*Band);
WO->panDstBands[0]=Band;
WO->pfnProgress=GDALTermProgress;
GDALWarpOperation *operation=new GDALWarpOperation;
if(operation)
operation->Initialize(WO);
operation->ChunkAndWarpImage(0, 0, NewCol, NewRow);
GDALDestroyWarpOptions(WO); WO=NULL; delete operation; operation=NULL;
GDALClose((GDALDatasetH) outimg); outimg=NULL;
Does the tutorial (just by itself, exactly as written) work on your machine?
Ans. To be honest I haven't checked. I, however, have gone through the
tutorial and after convincing myself that I have understood what to do, I
wrote the program.
______________________________
__________________________________________________
With many thanks,
Yours sincerely,
T.S. Prasad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150820/a2a350d8/attachment.html>
