[gdal-dev] Question
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Aug 26 08:27:28 PDT 2015
I made my test with GDAL 2.0 binaries from gisinternals by placing your osmconf.ini into \bin\gdal-data. Any change you do for the selected tags in osmconf.ini will have on effect on " ogrinfo hamburg-latest.osm.pbf points -so ". Don't do anything before you see that your osmconf.ini is used. I noticed right now while I was testing that I have several GDAL installations in my PATH, perhaps you have the same situation. Write PATH into your command line for checking it.
-Jukka-
Giorgio Ghiggini wrote:
> Hi,
> thanks a lot for the prompt response.
> I am using GISINTERNALS installation, and when I run the ogrinfo app it returns an error saying "all_tags not recognized as a valid field".
> I am not sure this installation is working well, my feeling is that any change I apply to the osmconf.ini are simply not used. Maybe the ogr2ogr and ogrinfo are not using the right path to get the osmconf.ini.
> Could you suggest me a Windows GDAL binary to install?
> Best regards,
> Giorgio
