[gdal-dev] vector VRT: Warning 1: Line 2: Attribute value should be single or double quoted.
Helmut Kudrnovsky
hellik at web.de
Wed Aug 26 11:16:15 PDT 2015
hi,
I have a vector VRT which refers to a CSV.
both files are attached to the mail:
chondrilla.vrt
<http://osgeo-org.1560.x6.nabble.com/file/n5221290/chondrilla.vrt>
chondrilla.csv
<http://osgeo-org.1560.x6.nabble.com/file/n5221290/chondrilla.csv>
when I do ogrinfo on the VRT, I get following warning:
>ogrinfo chondrilla.vrt
>Warning 1: Line 2: Attribute value should be single or double quoted. Going
on,
>but this is invalid XML that might be rejected in future versions.
>INFO: Open of `chondrilla.vrt'
> using driver `VRT' successful.
>1: chondrilla (Point)
a look into the CSV file:
"gbifid","datasetkey","occurrenceid",...
"895176382","834a4794-f762-11e1-a439-00145eb45e9a","",...
any idea what should be changed in the VRT or in CSV, as the attribute
values are quoted?
thanks
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/vector-VRT-Warning-1-Line-2-Attribute-value-should-be-single-or-double-quoted-tp5221290.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
