[gdal-dev] Call for discussion on RFC 59 (v2): GDAL/OGR utilities as a library
Kyle Shannon
kyle at pobox.com
Wed Aug 26 12:44:10 PDT 2015
On Wed, Aug 26, 2015 at 12:27 PM, Even Rouault
<even.rouault at spatialys.com> wrote:
> Hi,
> Summer of code 2015 being finished now, Faza's work now include librarification
> of gdalinfo, gdal_translate, gdalwarp and ogr2ogr. Faza will continue working
> on some other utilities.
Which other utilities are being considered? Has there been any
discussion or thoughts on this?
> We'd be happy to hear about your comments, especially on the API. So speak now
> please.
The API looks good to me.
How does documentation work for utilities now? I guess changes should
be documented in the *_lib.cpp or *_lib.h and also gdal_utilities.dox,
similar to how the utilities closely coupled with certain alg/ APIs
(gdalgrid for example).
> The overview of the work is there:
> https://trac.osgeo.org/gdal/wiki/rfc59_utilities_as_a_library
If I am reading correctly, a separate lib will now be created. Is
this to keep the building cleaner? Is there a problem with just adding
it to the libgdal C API?
> I'd like to call for a vote soon as I'd want that to be merged as soon as
> possible, so it gets more widely tested and to avoid increasing merge
> difficulties.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Thanks.
Kyle
