[gdal-dev] R: Question
Giorgio Ghiggini
gghiggini at gec-it.com
Wed Aug 26 23:42:34 PDT 2015
Thanks to all I know understood the problem.
I thought the SDKShell.bat was setting the variable permanently, while it is
not.
So running the ogrinfo and ogr2ogr within the SDKShell window it works
perfectly.
Thanks again for your help.
Best regards,
Giorgio
-----Messaggio originale-----
Da: gdal-dev-bounces at lists.osgeo.org
[mailto:gdal-dev-bounces at lists.osgeo.org] Per conto di Even Rouault
Inviato: Wednesday, August 26, 2015 7:22 PM
A: gdal-dev at lists.osgeo.org
Cc: Andre Joost
Oggetto: Re: [gdal-dev] Question
Le mercredi 26 août 2015 19:14:41, Andre Joost a écrit :
> Am 26.08.2015 um 17:27 schrieb Rahkonen Jukka (MML):
> > I noticed right now while I was
> > testing that I have several GDAL installations in my PATH, perhaps
> > you have the same situation. Write PATH into your command line for
> > checking it.
> To avoid those PATH assignments, I use the zip versions from
> Gisinternals, and expand it into a folder manually. When I run the
> SDKshell.bat, the path is set to that installation for all command line
> tasks, until the command window is closed.
> QGIS and OSGEO4W work the same, so I have no GDAL in my PATH at all.
That depends on what you can "your" PATH. SDKshell or OSGeo4W define a
temporary PATH (but indeed do not touch the user default PATH)
> And
> I can run GDAL versions from 1.6 to 2.0 on the same computer in
> parallel.
> I assume this is not possible on Linux.
Something that would be possible on Windows, but not on Linux?, come on ;-)
Of
course, it is possible to run several GDAL versions on Linux. PATH,
LD_LIBRARY_PATH, GDAL_DATA, PYTHONPATH are used for that
> HTH,
> André Joost
> gdal-dev mailing list
http://www.spatialys.com
