[gdal-dev] Issue with gdalchksum on Fedora 21 ppc64le?
Even Rouault even.rouault at spatialys.com
Thu Aug 27 03:30:15 PDT 2015
Le jeudi 27 août 2015 12:23:07, Gawade P a écrit :
> Thanks, Even.I have tried this change on ppc and there were some
> differences in the map values resulting in a small deviation in the
> final checksum value compared to the current output on x86
> The output on ppc with this change is:
> bash-4.2# gdalchksum.py nwt_grd.grd
> 28093
> 33690
> 20365
> 25856
> The expected values for band 2 and 3 are :
> 33626
> 20260
Interesting, I wouldn't have thought this to change the result of the
rounding, but who knows... Could you compare the color tables to check that
the differences are just within a +/- 1 amplitude ?
Thinking more, a cause for a difference of rounding should happen with negative
values, since casting truncates to the upper integer in case of negative
value. I'd think my proposed formula to be (slightly) more accurate in case of
negative slope, since it will only cast positive values.
> I have not tried this change on x86, will try and let you know. Could
> there be any implications of these changed values elsewhere in the
> code (Assuming that they will change on x86 as well)? I believe some
> test cases might fail as well...
Yes, once we get same results on both platforms, adjusting the expected
checksums of nwt_grd.py / nwt_grc.py scripts might be needed.
> On Thu, Aug 27, 2015 at 3:10 PM, Even Rouault
> <even.rouault at spatialys.com> wrote:
> > Le jeudi 27 août 2015 06:20:41, Gawade P a écrit :
> >> Good Morning, Even.
> >> I debugged this more, focusing, as you suggested, on the  computation
> >> of the colormap and looks like the difference in the value of the
> >> checksum is due to the difference in calculation of the color map
> >> values for negative slopes. The following lines of code in
> >> frmts/northwood/northwood.cpp, createIP() function are exhibiting
> >> different behavior on intel and ppc:
> >>      for( i = wm + 1; i < index; i++)
> >>         map[i].r = map[wm].r + (unsigned char)(((i - wm) * rslope) +
> >>         0.5); map[i].g = map[wm].g + (unsigned char)(((i - wm) *
> >>         gslope) + 0.5); map[i].b = map[wm].b + (unsigned char)(((i -
> >>         wm) * bslope) + 0.5);
> >> primarily, because of the (unsigned char) casting of the second
> >> operand. Looks like the behavior could be undefined if the float value
> >> resulting from the computation of the expression (((i - wm) * bslope)
> >> + 0.5) is negative, as would be the case for negative slope.
> >> For ppc, the expression  (unsigned char)(((i - wm) * bslope) + 0.5) is
> >> evaluating to zero, whenever the result of (((i - wm) * bslope) + 0.5)
> >> is -ve i.e. for -ve slope
> > Interesting. It is likely that the result of the cast (unsigned
> > char)negative_floating_point_value is undefined by the C standard and
> > there might be differences in behaviour according to the CPU here (seems
> > to be confirmed by
> > http://stackoverflow.com/questions/2490600/iphone-floats-cast-to-
> > unsigned-ints-get-set-to-0-if-they-are-negative)
> > I think the following should be portable:
> > map[i].r = (unsigned char)(map[wm].r + (i - wm) * rslope + 0.5);
> > map[i].g = (unsigned char)(map[wm].g + (i - wm) * gslope + 0.5);
> > map[i].b = (unsigned char)(map[wm].b + (i - wm) * bslope + 0.5);
> > Could you confirm ?
> > W might want to explictly clamp to [0,255] before casting, but according
> > to the formulas of the slope, I'm confident the result should already be
> > in [0,255.X] range.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
