[gdal-dev] Changing pixel values of GDAL VRT
cl clutz at virtualcitysystems.de
Tue Dec 15 08:23:44 PST 2015
Is it possible to manipulate the pixel values of a GDAL VRT and, if so, how?
The original data must remain unchanged.
I have a dataset which might be a bit rotated so that there are no data
values on the edges. I use region growing to find that parts on the edge to
not touch no data values in the actual area. I want to interpolate in the
actual area in a next step. Sometimes I might have e.g. a very large dataset
or ASCII data which can not be overwritten.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-pixel-values-of-GDAL-VRT-tp5241432.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
