[gdal-dev] Writing Coded Domain Values from GDAL
Even Rouault even.rouault at spatialys.com
Tue Dec 22 04:51:49 PST 2015
Le mardi 22 décembre 2015 12:46:29, Gane R a écrit :
> I tried to read the coded domain values from GDAL, I used special sql
> requests from GDAL as described in FileGeoDB driver. I got the values in
> the XML format.
> Is it possible to write coded domain values from GDAL using special sql
> request.
> I saw that it was possible from ESRI filegeodb API, can this be done from
> GDAL itself.
You could likely do it by using the XML_DEFINITION layer creation option.
It is for example used by ogr_fgdb_11() in
https://svn.osgeo.org/gdal/trunk/autotest/ogr/ogr_fgdb.py
In this test, the value of XML_DEFINITION is set to the content of
https://svn.osgeo.org/gdal/trunk/autotest/ogr/data/test_filegdb_field_types.xml
It doesn't test Coded Domain Values though , so I'm not completely sure this
will work if you had C.D.V in it.
Even
http://www.spatialys.com
