[gdal-dev] Writing Coded Domain Values from GDAL
Gane R gane.prog at gmail.com
Wed Dec 23 22:43:51 PST 2015
I saw the python example, I tried load the xml and used XML_DEFINITION on
layer creation option, I get runtime crash, I guess I am wrong some where
I loaded the XML and created a buffer
XML_DEFINITION=xmlcontent and sent in the layer creation options ? any
suggesion or code snippets already working
will be of great help
Gane
_
On Tue, Dec 22, 2015 at 6:21 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 22 décembre 2015 12:46:29, Gane R a écrit :
> > I tried to read the coded domain values from GDAL, I used special sql
> > requests from GDAL as described in FileGeoDB driver. I got the values in
> > the XML format.
> > Is it possible to write coded domain values from GDAL using special sql
> > request.
> > I saw that it was possible from ESRI filegeodb API, can this be done from
> > GDAL itself.
> You could likely do it by using the XML_DEFINITION layer creation option.
> It is for example used by ogr_fgdb_11() in
> https://svn.osgeo.org/gdal/trunk/autotest/ogr/ogr_fgdb.py
> In this test, the value of XML_DEFINITION is set to the content of
> https://svn.osgeo.org/gdal/trunk/autotest/ogr/data/test_filegdb_field_types.xml
> It doesn't test Coded Domain Values though , so I'm not completely sure
> this
> will work if you had C.D.V in it.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151224/4a09ecca/attachment.html>
