[gdal-dev] Call for discussion on RFC 53: OGR not-null constraints and default values
Even Rouault
even.rouault at spatialys.com
Thu Feb 5 04:15:31 PST 2015
This is a call for discussion on "RFC 53: OGR not-null constraints and default
values".
http://trac.osgeo.org/gdal/wiki/rfc53_ogr_notnull_default
Summary :
This RFC addresses handling of NOT NULL constraints and DEFAULT values for OGR
fields. NOT NULL constraints are useful to maintain basic data integrity and
are handled by most (all?) drivers that have SQL capabilities. Default fields
values may be used complementary or independantly of NOT NULL constraints to
specify the value a field must be assigned to if it is not provided when
inserting a feature into the layer.
Best regards,
Even
http://www.spatialys.com
