[gdal-dev] Call for discussion on RFC 53: OGR not-null constraints and default values
Even Rouault even.rouault at spatialys.com
Tue Feb 10 04:33:34 PST 2015
Le jeudi 05 février 2015 13:15:31, Even Rouault a écrit :
> Hi,
> This is a call for discussion on "RFC 53: OGR not-null constraints and
> default values".
> http://trac.osgeo.org/gdal/wiki/rfc53_ogr_notnull_default
I'll call for a vote tomorrow if nobody has points to raise.
> Summary :
> This RFC addresses handling of NOT NULL constraints and DEFAULT values for
> OGR fields. NOT NULL constraints are useful to maintain basic data
> integrity and are handled by most (all?) drivers that have SQL
> capabilities. Default fields values may be used complementary or
> independantly of NOT NULL constraints to specify the value a field must be
> assigned to if it is not provided when inserting a feature into the layer.
> Best regards,
> Even
http://www.spatialys.com
