[gdal-dev] gdal_merge vs gdalbuildvrt
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 6 02:25:01 PST 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> > gdalbuildvrt is a more
> > powerful tool that provides a virtual raster that acts as a 'window'
> > into the
> > input datasets, potentially with reprojection amidst other options.
> Small correction: gdalbuildvrt can only deal with datasets of the same
> projection.
...while gdaltindex utility http://www.gdal.org/gdaltindex.html that is also
a mosaic builder can deal with datasets in different projections. However,
this utility is specially made to create index files for Mapserver.
Hmm, I have loads of tileindex mosaics created with gdaltindex in shapefile
and Spatialite format, would be nice if I could utilize them also directly
with GDAL. I wonder it there is already a feature request about this.
-Jukka Rahkonen-
