[gdal-dev] gdal_merge vs gdalbuildvrt
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Fri Feb 6 02:33:38 PST 2015
Hello Jukka,
On 06/02/15 10:25, Jukka Rahkonen wrote:
> Even Rouault <even.rouault <at> spatialys.com> writes:
>>> gdalbuildvrt is a more
>>> powerful tool that provides a virtual raster that acts as a 'window'
>>> into the
>>> input datasets, potentially with reprojection amidst other options.
>> Small correction: gdalbuildvrt can only deal with datasets of the same
>> projection.
> ...while gdaltindex utility http://www.gdal.org/gdaltindex.html that
is also
> a mosaic builder can deal with datasets in different projections.
However,
> this utility is specially made to create index files for Mapserver.
Can you use these tileindices with the -tileindex option to gdalbuildvrt?
Perhaps not if they are in different projections...
> Hmm, I have loads of tileindex mosaics created with gdaltindex in shapefile
> and Spatialite format, would be nice if I could utilize them also
directly
> with GDAL. I wonder it there is already a feature request about this.
I agree this would be very useful, almost like having a tile index as a GDAL
data source. There is a related feature request here
<http://trac.osgeo.org/gdal/ticket/5762>.
Best regards,
Homme
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150206/d45adaa1/attachment.html>
