[gdal-dev] Dataset setProjection() method sets PROJCS to "unnamed"
Rebo Ghecin demolar at gmail.com
Tue Feb 10 03:10:14 PST 2015
I want to change my Dataset's projection but I have a trouble with it.
I have custom projection like below:
PROJCS["UTM3 Degree ITRF96 DOM39",
  GEOGCS["GCS_ITRF_1996",
    DATUM["D_ITRF_1996",
      SPHEROID["GRS_1980", 6378137.0, 298.257222101]],
    PRIMEM["Greenwich", 0.0],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH]],
  PROJECTION["Transverse_Mercator"],
  PARAMETER["central_meridian", 39.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","10103390"]]
and this is how I changed it:
String test = "PROJCS[\"UTM3 Degree ITRF96 DOM39\",
GEOGCS[\"GCS_ITRF_1996\",     DATUM[\"D_ITRF_1996\",
SPHEROID[\"GRS_1980\", 6378137.0, 298.257222101]],
PRIMEM[\"Greenwich\", 0.0],    UNIT[\"degree\", 0.017453292519943295],
 AXIS[\"Longitude\", EAST],    AXIS[\"Latitude\", NORTH]],
 PROJECTION[\"Transverse_Mercator\"],  PARAMETER[\"central_meridian\",
39.0],  PARAMETER[\"latitude_of_origin\", 0.0],
 PARAMETER[\"scale_factor\", 1.0],  PARAMETER[\"false_easting\", 500000.0],
 PARAMETER[\"false_northing\", 0.0],  UNIT[\"m\", 1.0],  AXIS[\"x\", EAST],
 AXIS[\"y\", NORTH],  AUTHORITY[\"EPSG\",\"10103390\"]]";
SpatialReference oSRS = new SpatialReference();
oSRS.ImportFromWkt(test);
inputDataset.SetProjection(oSRS.ExportToWkt());
and it returns
PROJCS["unnamed",
  GEOGCS["GCS Name = GCS_ITRF_1996",
    DATUM["Datum = D_ITRF_1996",
      SPHEROID["Ellipsoid = GRS_1980", 6378137.0, 298.257222101]],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH]],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH]]
I have created custom.wkt file and include it in epsg.wkt at "gdal_data"
folder but this is also not working for me.
custom.wkt content:
10103390,PROJCS["UTM3 Derece ITRF96
DOM39",GEOGCS["GCS_ITRF_1996",DATUM["D_ITRF_1996",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",39.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],
Also I tried to set PROJCS like this
oSRS.SetProjCS("My Proj"); but didn't work.
Any idea with this?
Thanks
Rebo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150210/702dbfb5/attachment-0001.html>
