[gdal-dev] SQLite dialect in OGRDataSource::ExecuteSQL
Pierluigi Guasqui guasqui at actgate.com
Tue Feb 10 03:47:46 PST 2015
Hi All!
I am using the GDAL/OGR functions to query a shapefile. This is a sample
code I have been successfully running so far:
    OGRDataSource *poDS = OGRSFDriverRegistrar::Open(
    "some/path/to/myshapefile.shp" );
    OGRLayer *poLayer = poDS->ExecuteSQL( "select * from myshapefile",
    NULL, NULL );
    // fetching result features from "poLayer"
    poDS->ReleaseResultSet( poLayer );
    OGRDataSource::DestroyDataSource(poDS);
As you can see, I am currently using the OGR SQL dialect, as I am
passing NULL as the third parameter of the OGRDataSource::ExecuteSQL
function.
Now I am trying to extend the SQL syntax to be able to use the OGR
SQLite dialect. I have successfully recompiled GDAL 1.11.1 with SQLite
support (version 3.8.5) but when I try to execute the same sample code
(passing "SQLITE" as the 3rd argument of the OGRDataSource::ExecuteSQL
function) I am getting the following error:
    In ExecuteSQL(): sqlite3_prepare(select * from myshapefile): no such
    table: myshapefile
What is the table name that contains the shapefile features that I can
use in my SQL queries?
Thank you!
Pierluigi Guasqui
Software Engineer
Applied Coherent Technology Corporation (ACT)
www.actgate.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150210/a4c75964/attachment.html>
