[gdal-dev] SQLite dialect in OGRDataSource::ExecuteSQL
Even Rouault
even.rouault at spatialys.com
Tue Feb 10 04:42:12 PST 2015
Le mardi 10 février 2015 12:47:46, Pierluigi Guasqui a écrit :
> Hi All!
> I am using the GDAL/OGR functions to query a shapefile. This is a sample
> code I have been successfully running so far:
> OGRDataSource *poDS = OGRSFDriverRegistrar::Open(
> "some/path/to/myshapefile.shp" );
> OGRLayer *poLayer = poDS->ExecuteSQL( "select * from myshapefile",
> NULL, NULL );
> // fetching result features from "poLayer"
> poDS->ReleaseResultSet( poLayer );
> OGRDataSource::DestroyDataSource(poDS);
> As you can see, I am currently using the OGR SQL dialect, as I am
> passing NULL as the third parameter of the OGRDataSource::ExecuteSQL
> function.
> Now I am trying to extend the SQL syntax to be able to use the OGR
> SQLite dialect. I have successfully recompiled GDAL 1.11.1 with SQLite
> support (version 3.8.5) but when I try to execute the same sample code
> (passing "SQLITE" as the 3rd argument of the OGRDataSource::ExecuteSQL
> function) I am getting the following error:
> In ExecuteSQL(): sqlite3_prepare(select * from myshapefile): no such
> table: myshapefile
> What is the table name that contains the shapefile features that I can
> use in my SQL queries?
Pierluigi,
That should work... If you tried to configure GDAL several times, perhaps you
should do a make clean.
Could you try defining CPL_DEBUG=ON as environment variable and rerun your
code. You should normally see a statement like the following one to create the
SQLite virtual table that matches the shapefile layer :
OGR2SQLITE: sqlite3_declare_vtab(CREATE TABLE "poly"("AREA" FLOAT,"EAS_ID"
FLOAT,"PRFEDEA" VARCHAR(16),OGR_STYLE VARCHAR HIDDEN,"GEOMETRY"
BLOB_POLYGON_2D_50000))
Even
http://www.spatialys.com
