[gdal-dev] SQLite dialect in OGRDataSource::ExecuteSQL
Even Rouault
even.rouault at spatialys.com
Tue Feb 10 10:19:58 PST 2015
Le mardi 10 février 2015 19:05:58, Pierluigi Guasqui a écrit :
> Even,
> here is the complete output:
> Shape: DBF Codepage = LDID/87 for
That was useful. Pasting the SQL into SQLite3 console shows :
Error: duplicate column name: MET
Indeed there's a "met" and "MET" columns in the shapefile. OGR drivers and core
rarely handle that properly, and it seems that SQLite3 doesn't like it too. So
you should rename one of the column, or use for example create a VRT with
http://svn.osgeo.org/gdal/branches/1.11/gdal/swig/python/samples/ogr2vrt.py
and hand-edit to do the renaming.
Even
http://www.spatialys.com
