[gdal-dev] upper-/lower-case for names in DNC-charts structures (VPF).
Even Rouault
even.rouault at spatialys.com
Mon Jan 12 02:51:03 PST 2015
Selon Malm Paul <paul.malm at saabgroup.com>:
> Hi, list!
> We're trying to read a DNC chart (VPF format) in a Linux OS. The OGR driver
> reports that files are not found. It works in Windows.
> The problems seems to be caseing of the names, if we recursively rename the
> file paths to lowercase it works. But it does not work with the original
> files.
> We have searched the "VPF" files and can see that the referenced filenames is
> no different from the filenames on disc, does the OGR driver force names that
> are read in the files to be lower case?
> Our biggest problem is that the files are read directly from CD and can't be
> renamed prior reading.
> Does anyone have a solution for this?
The issue is or was in OGDI itself. At the time where VPF was a hot topic, I
remind having patched OGDI for that, and presumably contributed the patch
upstream. It must be in ogdi 3.2.0beta2 or something like that.
> Kind regards,
> Paul
http://www.spatialys.com
