[gdal-dev] gdal_rasterize increase memory usage
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Jul 16 07:36:25 PDT 2015
I had the same problem with gdal_warp. I recompiled the code using the latest ms visual studio community and the buffer was increased from 15 Mb to 1.5 GB. It's was a first for me because I usually work in python. It's easy to do.
That fixed all the issue. I am told that buffer size is arbitrary and what may be good for one person may cause problems to another if, for example, a person launches many instances of the same program in parallel.
Best to recompile if the option is there. There is a page on the gdal web site explaining how to do it.
Good luck
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jul 16, 2015 05:15, jramm <jamessramm at gmail.com> wrote:
> gdal_rasterize is limited to use just 10MB of memory (line ~640 of
> gdalrasterize.cpp).
> Is there anyway to change this (without having to recompile?)
> I'm noticing that changing the output data format from Byte to Int16 or even
> Int32 drastically reduces performance. This must be because the strict
> memory limits imposed by gdal_rasterize means that the amount of data it
> reads in one go is exponentially reduce each time I increase the integer
> size. Thus it has to loop through the polygon set many more times.
> I'm seeing drastic slow down by just changing from Byte to Int16 when using
> gdal_rasterize (8-10 times slower)
> Given that even the cheapest desktop has at least 1GB of RAM, isn't the
> scanline buffer size over conservative?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-rasterize-increase-memory-usage-tp5215862.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
