[gdal-dev] Strange effect in gdalwarp output
Even Rouault even.rouault at spatialys.com
Wed Jul 22 04:34:26 PDT 2015
Monobakht,
Probably due to the bow-tie effect of the MODIS scanning sensor. gdalwarp cannot currently deal with that correctly.
Discussed recently in this thread:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdalwarp-problems-with-MODIS-L1B-td5206583.html
Best regards,
Even
> This question was posted originally at
> http://gis.stackexchange.com/questions/154959/strange-effect-in-gdalwarp-ou
> tput
> <http://gis.stackexchange.com/questions/154959/strange-effect-in-gdalwarp-
> output> but I did not get any helpful response. Here is the problem:
> I am using gdalwarp in python to extract and re-project reflectance bands
> from MODIS level 1B (MOD021km). The command that I am using is the
> following:
> gdalwarp -of GTIFF -tps -t_srs EPSG:4326 -tr 0.01 0.01 -r bilinear
> -overwrite
> HDF4_EOS:EOS_SWATH:"C:\tmp\MYD021KM.A2007094.0935.006.2012075055042.hdf":MO
> DIS_SWATH_Type_L1B:EV_500_Aggr1km_RefSB C:\tmp\Output.tif
> It converts the hdf subdataset without any problem but the output file
> seems to have some sort of artifact, specially close to the edges. (See
> below) <http://osgeo-org.1560.x6.nabble.com/file/n5216470/gdalwarp.jpg>
> I converted the same data using Modis Conversion Toolkit (MCTK) and it
> seems to be much better. (Below)
> <http://osgeo-org.1560.x6.nabble.com/file/n5216470/MCTK.jpg>
> I tried different resampling method and different output projection but
> still the same results! Is there anyone having this issue with gdalwarp?
> P.S. The data can be downloaded from this address:
> ftp://ladsweb.nascom.nasa.gov/allData/6/MYD021KM/2007/094/MYD021KM.A2007094
> http://osgeo-org.1560.x6.nabble.com/Strange-effect-in-gdalwarp-output-tp52
> 16470.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
