[gdal-dev] gdal-dev Digest, Vol 133, Issue 17
Pieter Kempeneers
kempenep at gmail.com
Tue Jun 9 08:20:19 PDT 2015
> Message: 1
> Date: Tue, 9 Jun 2015 14:31:48 +0000
> From: "Ronquillo, Edgar Nahum" <eronquillo at lanl.gov>
> To: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] Overlay shapefile onto Geotiff image
> Message-ID:
> 2086CE7E967C1B4F9D5897BE1C3C746F3119455B at ECS-EXG-P-MB01.win.lanl.gov>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> I have been working on this issue for quite a while. I currently have a
> GeoTiff image and a shapefile. I would like to overlay the shapefile on the
> Geotiff, is this possible with Gdal? I looked into gdal_rasterize but I
> just don't know how to incorporate it with what I need. A code to start
> with would be great if possible. Or maybe point me into the right direction
> of probably other libraries that could do this.
Hi Edgar,
What is it exactly you want to do with the overlay? If it is just cropping
the Geotiff, you can use gdalwarp (check option -crop_to_cutline). If you
want to extract the raster pixels in the Geotiff covered by the shapefile
(all pixels, average, etc.), you can use pkextract from pktools (
http://pktools.nongnu.org/html/pkextract.html). It also has a processing
toolbox plugin for QGIS (http://plugins.qgis.org/plugins/pktools/). The
code is open source (GPLv3).
Pieter.
2015-06-09 16:39 GMT+02:00 <gdal-dev-request at lists.osgeo.org>:
> Send gdal-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
> 1. Overlay shapefile onto Geotiff image (Ronquillo, Edgar Nahum)
> 2. Re: assigning vertical datum to image files (Newcomb, Doug)
> Message: 1
> Message-ID:
> Hi,
> Thanks for the help
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/028f5e7e/attachment-0001.html
> Message: 2
> Date: Tue, 9 Jun 2015 10:38:30 -0400
> From: "Newcomb, Doug" <doug_newcomb at fws.gov>
> To: Even Rouault <even.rouault at spatialys.com>
> Cc: gdal dev <gdal-dev at lists.osgeo.org>, Hermann Peifer
> <peifer at gmx.eu>
> Subject: Re: [gdal-dev] assigning vertical datum to image files
> Message-ID:
> CALQGVr2pLpssKbeenSWsk4qULUs7t1WT9-G+ThQHXQ947-mTLA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Evan,
> Here is the output from gdalinfo wit the expanded config.
> Note the error messages on failure to load datum shift files for the
> corner coordinates.
> I'll upgrade to RC1 and check that again, but thought I would mention.
> gdalinfo --config GTIFF_REPORT_COMPD_CS YES D05_37_30081003_20141231.tif
> Driver: GTiff/GeoTIFF
> Files: D05_37_30081003_20141231.tif
> Size is 1000, 1000
> Coordinate System is:
> COMPD_CS["unknown",
> PROJCS["NAD83(2011) / North Carolina (ftUS)",
> GEOGCS["NAD83(2011)",
> DATUM["NAD83_National_Spatial_Reference_System_2011",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","1116"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","6318"]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",36.16666666666666],
> PARAMETER["standard_parallel_2",34.33333333333334],
> PARAMETER["latitude_of_origin",33.75],
> PARAMETER["central_meridian",-79],
> PARAMETER["false_easting",2000000],
> PARAMETER["false_northing",0],
> UNIT["US survey foot",0.3048006096012192,
> AUTHORITY["EPSG","9003"]],
> AXIS["X",EAST],
> AXIS["Y",NORTH],
> AUTHORITY["EPSG","6543"]],
> VERT_CS["NAVD88 height",
> VERT_DATUM["North American Vertical Datum 1988",2005,
> EXTENSION["PROJ4_GRIDS","g2012a_conus.gtx,g2012a_alaska.gtx,g2012a_guam.gtx,g2012a_hawaii.gtx,g2012a_puertorico.gtx,g2012a_samoa.gtx"],
> AUTHORITY["EPSG","5103"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Up",UP],
> AUTHORITY["EPSG","5703"]]]
> Origin = (3010000.000000000000000,805000.000000000000000)
> Pixel Size = (5.000000000000000,-5.000000000000000)
> Metadata:
> AREA_OR_POINT=Area
> DataType=Generic
> Image Structure Metadata:
> COMPRESSION=DEFLATE
> INTERLEAVE=BAND
> Corner Coordinates:
> ERROR 1: failed to load datum shift file
> Upper Left ( 3010000.000, 805000.000)
> Lower Left ( 3010000.000, 800000.000)
> Upper Right ( 3015000.000, 805000.000)
> Lower Right ( 3015000.000, 800000.000)
> Center ( 3012500.000, 802500.000)
> Band 1 Block=1000x2 Type=Float32, ColorInterp=Gray
> Description = Layer_1
> Min=-3.000 Max=-3.000
> Minimum=-3.000, Maximum=-3.000, Mean=-3.000, StdDev=0.000
> NoData Value=-3.40282306073709653e+38
> Metadata:
> LAYER_TYPE=athematic
> STATISTICS_COVARIANCES=0
> STATISTICS_MAXIMUM=-3
> STATISTICS_MEAN=-3
> STATISTICS_MEDIAN=0
> STATISTICS_MINIMUM=-3
> STATISTICS_MODE=0
> STATISTICS_SKIPFACTORX=1
> STATISTICS_SKIPFACTORY=1
> STATISTICS_STDDEV=0
> Doug
> On Tue, Jun 9, 2015 at 10:21 AM, Newcomb, Doug <doug_newcomb at fws.gov>
> wrote:
> > Evan,
> > I went back and checked. The .aux.xml sidecar files with the img files
> > do not appear to have projection information.
> > Doug
> > On Tue, Jun 9, 2015 at 9:32 AM, Even Rouault <even.rouault at spatialys.com
> > wrote:
> >> Selon "Newcomb, Doug" <doug_newcomb at fws.gov>:
> >> > Thanks!
> >> > That should work in this case to build the virtual raster. I'm still
> >> > curious about assigning the vertical datum to the rasters.
> >> Doug,
> >> I'm a bit surprised that the HFA driver reports a SRS with a VERTCS node
> >> as a
> >> child of the PROJCS node. I believe this is an incorrect WKT definition.
> >> There
> >> should rather be a COMPD_CS root note with 2 children: a PROJCS node for
> >> the
> >> horizontal CRS and a VERTCS node for the vertical CRS. Perhaps this SRS
> >> string
> >> is defined in the .aux.xml sidecar files that are apparently present ?
> >> Regarding your question, there are a few EPSG codes that correspond to
> >> aCOMPD_CS, for example 6349. Otherwise, GDAL allows to build a custom
> >> COMPD_CS
> >> with the syntax EPSG:XXXX+YYYY where XXXX is the EPSG code of the
> >> horizontal SRS
> >> and YYYY the EPSG code of the vertical SRS. In your case that should be
> >> EPSG:6543+5703 I think
> >> So you can do things like "gdal_translate in.tif out.tif -a_srs
> >> EPSG:6543+5703"
> >> If you read back out.tif, you will only get the horizontal SRS by
> >> default. This
> >> was for backward compatibility reason I think. But if you specify
> >> "--config
> >> GTIFF_REPORT_COMPD_CS YES" you will get the COMPD_CS.
> >> Even
> >> > Doug
> >> > On Tue, Jun 9, 2015 at 1:48 AM, Hermann Peifer <peifer at gmx.eu> wrote:
> >> > > About your initial problem:
> >> > > > but gdalbuildvrt complained, informing me that
> >> > > > they were not in the same projection.
> >> > > What about using the below gdalbuildvrt option?
> >> > > Hermann
> >> > > -allow_projection_difference:
> >> > > (starting with GDAL 1.7.0) When this option is specified, the
> utility
> >> will
> >> > > accept to make a VRT even if the input datasets have not the same
> >> > > projection. Note: this does not mean that they will be reprojected.
> >> Their
> >> > > projection will just be ignored.
> >> > > Source: http://www.gdal.org/gdalbuildvrt.html
> >> > > On 2015-06-08 21:01, Newcomb, Doug wrote:
> >> > >> Hi Folks,
> >> > >> I have a directory of 783 .img format Lidar - based DEMs in the
> same
> >> > >> projection, North Carolina State Plane Feet (2011) , NAD 83 ,
> >> NVD88. I
> >> > >> was going to use gdalbuildvrt to create a single virtual image for
> >> the
> >> > >> area, but gdalbuildvrt complained, informing me that they were not
> in
> >> > >> A couple of quick bash scripts/commands
> >> > >> for x in *.img; do gdalinfo $x >>img_info.txt;done
> >> > >> and
> >> > >> grep PROJCS img_info.txt|sort|uniq -c
> >> > >> gives me the following:
> >> > >> 437
> >> PROJCS["NAD_1983_2011_StatePlane_North_Carolina_FIPS_3200_Ft_US",
> >> > >> 346
> >> PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet_2011",
> >> > >> gdalinfo gives the following for each type of file ( origin section
> >> > >> clipped out) :
> >> > >> Driver: HFA/Erdas Imagine Images (.img)
> >> > >> Files: D05_37_20878102_20141231.img
> >> > >> D05_37_20878102_20141231.img.aux.xml
> >> > >> Size is 1000, 1000
> >> > >> GEOGCS["GCS_NAD_1983_2011",
> >> > >> DATUM["NAD_1983_2011",
> >> > >> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> >> > >> PRIMEM["Greenwich",0.0],
> >> > >> UNIT["Degree",0.017453292519943295]],
> >> > >> PARAMETER["False_Easting",2000000.0],
> >> > >> PARAMETER["False_Northing",0.0],
> >> > >> PARAMETER["Central_Meridian",-79.0],
> >> > >> PARAMETER["Standard_Parallel_1",34.3333333333333],
> >> > >> PARAMETER["Standard_Parallel_2",36.1666666666667],
> >> > >> PARAMETER["Latitude_Of_Origin",33.75],
> >> > >> UNIT["Foot_US",0.30480060960121924],
> >> > >> VERTCS["NAVD_1988_Foot_US",
> >> > >> VDATUM["North_American_Vertical_Datum_1988"],
> >> > >> PARAMETER["Vertical_Shift",0.0],
> >> > >> PARAMETER["Direction",1.0],
> >> > >> UNIT["Foot_US",0.3048006096012192]]]
> >> > >> Files: D05_37_20957301_20141231.img
> >> > >> D05_37_20957301_20141231.img.aux.xml
> >> > >> Size is 1000, 1000
> >> > >> UNIT["Degree",0.0174532925199433]],
> >> > >> PARAMETER["False_Easting",2000000.002616666],
> >> > >> PARAMETER["Standard_Parallel_1",34.33333333333334],
> >> > >> PARAMETER["Standard_Parallel_2",36.16666666666666],
> >> > >> In theory, these should all be EPSG:6543, so just assigning the
> >> correct
> >> > >> horizontal projection/datum with the epsg code should make things
> >> > >> usable. (i.e,
> >> > >> gdal_translate -a_"srs epsg:6543" --config GDAL_CACHEMAX 512 -of
> >> GTiff
> >> > >> -co COMPRESS=DEFLATE -co PREDICTOR=3 in.img out.tif ) ( Thank you
> >> for
> >> > >> the EPSG:6543 projection support in GDAL 2.0!)
> >> > >> However, this only assigns the horizontal infomation, how does one
> >> > >> assign a vertical datum with a horizontal EPSG code?
> >> > >> I see the NVD88 code in vertcs.csv , but how would I implement it
> in
> >> the
> >> > >> above command?
> >> > >> Using gdal 2.0 Beta2
> >> > >> Doug
> >> > >> Doug Newcomb
> >> > >> USFWS
> >> > >> Raleigh, NC
> >> > >> 919-856-4520 ext. 14 doug_newcomb at fws.gov <mailto:
> >> > >> The opinions I express are my own and are not representative of the
> >> > >> official policy of the U.S.Fish and Wildlife Service or Dept. of
> the
> >> > >> Interior. Life is too short for undocumented, proprietary data
> >> formats.
> >> > >> _______________________________________________
> >> > Doug Newcomb
> >> > USFWS
> >> > Raleigh, NC
> >> > official policy of the U.S.Fish and Wildlife Service or Dept. of the
> >> formats.
> >> Spatialys - Geospatial professional services
> >> http://www.spatialys.com
> > Doug Newcomb
> > USFWS
> > Raleigh, NC
> > Interior. Life is too short for undocumented, proprietary data formats.
> Doug Newcomb
> USFWS
> Raleigh, NC
> URL: <
> http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/323e8726/attachment.html
> End of gdal-dev Digest, Vol 133, Issue 17
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/9abaee1e/attachment-0001.html>
