[gdal-dev] Gdal_translate considers --config means -co
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Jun 18 07:35:37 PDT 2015
Spotted this from gis.stackexchange
http://gis.stackexchange.com/questions/151153/is-gdal-translate-ignoring-the-cpl-tmpdir-switch
I repeated the test on Windows with GDAL 2.0 and it seems indeed that using
--config option in the beginning of gdal_translate command fails. Like it
would be cut at "-co" and interpreted to mean something totally different.
Moving --config to the end of the command leads to success.
-Jukka Rahkonen-
