[gdal-dev] python ogr feature didn't save attributes
Luca Delucchi lucadeluge at gmail.com
Tue Jun 23 06:49:07 PDT 2015
Hi devs,
I'm writing a function to cycle inside the feature and update a column
of attribute table, if I print the feature with DumpReadable() I can
see the right attributes but when the script finish the final
shapefile has no attribute table, any idea?
This is the relevant part of code
featureDefn = lay0.GetLayerDefn()
field = ogr.FieldDefn(out_col, ogr.OFTReal)
featureDefn.AddFieldDefn(field)
# loop through input layer
for inFeature in lay0:
    volu = None
    # create a new feature
    outFeature = ogr.Feature(featureDefn)
    # copy the attributes and set geometry
    outFeature.SetFrom(inFeature)
    spec = inFeature.GetField(str(specie))
    diameter = inFeature.GetField(str(diam))
    heig = inFeature.GetField(str(height))
    if diameter > 85:
        diameter = 85
    if spec in ['fa', 'al']:
        if diameter > 4.0091:
            values = CODES[spec]
            volu = formula_vol(values['a'], values['b'], values['c'],
                                values['d0'], diameter, heig)
    elif spec in ['ab', 'ar', 'la', 'pc', 'pn', 'ps']:
        if diameter > 3.69465:
    outFeature.SetField(out_col, volu)
    outFeature.DumpReadable()
    # add the feature to the output layer
    outLayer.CreateFeature(outFeature)
    outFeature = None
outLayer = None
outDS = None
and this one of outFeature.DumpReadable()
OGRFeature(20150304_AREEINV_trees):-1
  nr_progr_P (Integer) = 25
  AREAINV (Integer) = 155
  DBH_cm (Real) = 55.500000000000000
  Heigth_m (Real) = 33.600000000000001
  H_m (Real) = (null)
  EST_UTM32W (Real) = 635874.174400790012442
  NORD_UTM32 (Real) = 5127869.940315400250256
  G_m2 (Real) = 0.241922065000000
  V/M (String) = V
  Crown_A_m2 (Real) = (null)
  NOTE (String) = (null)
  RBH_m (Real) = 0.277500000000000
  Abbr_SPECI (String) = ar
  TIPOLOGIA (String) = pianta
  SP_Latino (String) = Picea_abies
  SP_Inglese (String) = Norway_spruce
  prova_volume (Real) = 2.46353029399417
  POINT (635874.174400790012442 5127869.940315400250256)
and this is the output of ogrinfo
Layer name: prova
Geometry: Point
Feature Count: 1630
Extent: (634916.793252, 5127012.958636) - (637692.035641, 5129718.805166)
Layer SRS WKT:
PROJCS["WGS_1984_UTM_Zone_32N",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_84",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
FID: Real (11.0)
thanks a lot
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
