[gdal-dev] python ogr feature didn't save attributes
Even Rouault even.rouault at spatialys.com
Tue Jun 23 07:02:25 PDT 2015
Luca,
> I'm writing a function to cycle inside the feature and update a column
> of attribute table, if I print the feature with DumpReadable() I can
> see the right attributes but when the script finish the final
> shapefile has no attribute table, any idea?
> This is the relevant part of code
> featureDefn = lay0.GetLayerDefn()
> field = ogr.FieldDefn(out_col, ogr.OFTReal)
> featureDefn.AddFieldDefn(field)
As suggested in http://gdal.org/python/osgeo.ogr.FeatureDefn-
class.html#AddFieldDefn , you must call CreateField() on the layer object
instead.
Even
http://www.spatialys.com
