[gdal-dev] Bindings and typemaps
Ari Jolma
ari.jolma at gmail.com
Mon Mar 9 02:35:31 PDT 2015
09.03.2015, 11:18, Even Rouault kirjoitti:
> Le lundi 09 mars 2015 08:08:34, Ari Jolma a écrit :
>> 08.03.2015, 23:49, Even Rouault kirjoitti:
>>> Le dimanche 08 mars 2015 22:20:50, Ari Jolma a écrit :
>>> Ari,
>>> Your proposal looks reasonable (but I don't pretend mastering SWIG and
>>> anticipating all side effects) and you can experiment with that if you
>>> wish. Please make sure to test the 4 supported languages. If there are
>>> breakage you don't know how to fix, it will require coordination with me
>>> and Tamas and that should perhaps be done through a ticket with a patch,
>>> or a dedicated branch.
>> Wouldn't the whole thing be best to be a branch from the beginning.
> Yes probably.
I'll do that.
IMO the goal would be to reduce language specific ifdefs from the
general bindings, and remove unnecessary typedefs.
For example there are a lot of
#ifndef SWIGJAVA
%feature( "kwargs" ) CopyLayer;
#endif
Is there a reason keywords arguments are not enabled with -keyword
option for languages that support them?
Ari
>> If I
>> branch the whole swig tree like this
>> http://emilsblog.lerch.org/2010/03/working-with-feature-branch-in.html
>> then it would assumably be quite simple to test all the changes in all
>> languages.
> Yes, I generally branch a whole repository, but a subtree might do too.
> Or if you prefer Git, you could fork https://github.com/OSGeo/gdal
>> I don't know how to test C# and Java bindings. Especially C#
>> is probably out of what I can do.
>> Ari
>>> Even
