[gdal-dev] Bindings and typemaps
Even Rouault
even.rouault at spatialys.com
Mon Mar 9 02:18:35 PDT 2015
Le lundi 09 mars 2015 08:08:34, Ari Jolma a écrit :
> 08.03.2015, 23:49, Even Rouault kirjoitti:
> > Le dimanche 08 mars 2015 22:20:50, Ari Jolma a écrit :
> > Ari,
> > Your proposal looks reasonable (but I don't pretend mastering SWIG and
> > anticipating all side effects) and you can experiment with that if you
> > wish. Please make sure to test the 4 supported languages. If there are
> > breakage you don't know how to fix, it will require coordination with me
> > and Tamas and that should perhaps be done through a ticket with a patch,
> > or a dedicated branch.
> Wouldn't the whole thing be best to be a branch from the beginning.
Yes probably.
> If I
> branch the whole swig tree like this
> http://emilsblog.lerch.org/2010/03/working-with-feature-branch-in.html
> then it would assumably be quite simple to test all the changes in all
> languages.
Yes, I generally branch a whole repository, but a subtree might do too.
Or if you prefer Git, you could fork https://github.com/OSGeo/gdal
> I don't know how to test C# and Java bindings. Especially C#
> is probably out of what I can do.
> Ari
> > Even
http://www.spatialys.com
