[gdal-dev] [GSOC] Integration of cpp GDAL utilities into GDAL core library
Volker Wichmann Volker.Wichmann at uibk.ac.at
Thu Mar 19 03:32:17 PDT 2015
Hi Nishith,
On 03/18/2015 08:27 PM, Nishith Maheshwari wrote:
> Hi,
> I am a masters student from IIIT Hyderabad and currently in my final
> year of study and working in the Lab for Spatial Informatics here.
> I was a part of GSOC 2014 and worked on the project *'Schematization
> Plugin for QGIS'* last year [1][2].
> I am interested in the project *'Integration of cpp GDAL utilities into
> GDAL core library'* .
> I have already looked at a few codes of gdal utilities available in the
> 'apps' folder of the sourcecode and had a few queries -
> 1. From my understanding of the project description, the aim is to
> refactor the individual codes of gdal utilities by removing the main()
> and making them available in the form of functions. These functions can
> then be accessed by another function like GDALRunUtility() which can be
> used to call them individually using specific parameters. Please let me
> know if I'm thinking in the right direction.
> 2. If we are implementing individual functions for every utility we
> might not require a separate layer of interaction in the form of
> GDALRunUtility(). Any thoughts?
yes, the idea was to move the functionality of the gdal utilities to
GDAL core in order to have it available directly when using the library
and thus to facilitate their usage from "external" programs. The
functionality should be usable with the GDALRunUtility() function. This
would avoid e.g. a system call to a tool or code duplication which is
currently needed in order to create a GDAL vrt for example.
It is not intended to remove the GDAL tools, but they would have to be
reworked to just provide the parameter interface and then to call
GDALRunUtility() themselves. The idea to have a GDALRunUtility()
function is to have a unique entry point and common interface to all
tool functionality.
Best regards,
Volker
> [1] http://hub.qgis.org/wiki/quantum-gis/nishithm
> [2] https://github.com/nishithm/schematization
> Regards,
> Nishith Maheshwari
> IIIT Hyderabad, India
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
