[gdal-dev] RFC 44: Add Parseable Output Formats for ogrinfo and gdalinfo
Homme Zwaagstra hrz at geodata.soton.ac.uk
Mon Mar 30 00:32:27 PDT 2015
P.S. on the proposal below, perhaps things could be 'standardised' even
more by
including the cornerCoordinates in both wgs84 and native coordinate systems
(much like gdalinfo does at the moment).  In this way you can be
guaranteed of
getting geojson output in its default coordinate system.  e.g.:
{ "cornerCoordinates":
   { "wgs84": ... GeoJSON FeatureCollection transformed to EPSG:4326 ...,
     "native: ... GeoJSON FeatureCollection in native coordinates ...
Best regards,
Homme
On 30/03/15 08:16, Homme Zwaagstra wrote:
 > Regarding the JSON output, I would prefer the top level
"cornerCoordinates"
 > property to be a GeoJSON feature collection rather than the current
custom data
 > structure.  Currently it is:
 >     "cornerCoordinates": {
 >         "upperLeft": [
 >             440720.000,
 >             3751320.000
 >         "lowerLeft": [
 >             440720.000,
 >             3750120.000
 >         "upperRight": [
 >             441920.000,
 >             3751320.000
 >         "lowerRight": [
 >             441920.000,
 >             3750120.000
 >         "center": [
 >             441320.000,
 >             3750720.000
 > I think the following would be more useful:
 >   { "type": "FeatureCollection",
 >     "bbox": [440720.000, 3750120.000, 441920.000, 3751320.000],
 >     "features": [Hi,
 > On 29/03/15 23:58, Robert Coup wrote:
 > > Hi,
 > > Good work, thanks for taking this on!
 > Yes, this will be very useful!
 > > 2: In terms of the proposed gdalinfo JSON...
 > > b) personally I'd prefer to be slightly more verbose in attribute
naming. eg. block -> blockSize, colorInterp -> colorInterpolation, proj
-> proj4
 > I agree as that will make it easier to scan through the output
without raising
 > questions or needing to refer to specs. E.g. does colorInterp mean color
 > interpretation or interpolation?!
 > > c) There's support for multiple RATs in a single dataset, but the
JSON format only allows one. Maybe rats: {"name": {... attributes...}}?
 > > d) HDF-derived formats (and probably some others) have support for
multiple datasets/component images. Is that something we could
incorporate (maybe with a top-level object surrounding each dataset
description)?
 > > There may be a few other elements where there's support (either now
or in the forseeable future) for multiple items. @Even, any thoughts?
 > Yes, it would be nice to have support (or the possibility of support)
for the
 > information concerning the larger gdal data model.  This kind of high
level
 > declarative API is really useful in covering a lot common use cases
e.g. getting
 > the extent of a raster, and finding out what files define it.
 > The command line parseable output format interface in itself would be
great, but
 > the icing on the cake would be the combination of this RFC with the
GSOC 2015
 > 'Integration of cpp GDAL utilities into GDAL core library' exposing
this as a
 > fully fledged core API.
 > > 3: Keen to see the ogrinfo equivalent!
 > Agreed!
 >         { "type": "Feature",
 >           "geometry": {"type": "Point", "coordinates": [440720.000,
3751320.000]},
 >           "properties": {"position": "upperLeft"}
3750120.000]},
 >           "properties": {"position": "lowerLeft"}
 >           "geometry": {"type": "Point", "coordinates": [441920.000,
3751320.000]},
 >           "properties": {"position": "upperRight"}
3751320.000]},
 >           "properties": {"position": "lowerRight"}
 >           "geometry": {"type": "Point", "coordinates": [441320.000,
3750720.000]},
 >           "properties": {"position": "center"}
 > It is more verbose, but seeing as the output is designed for parsing,
this
 > shouldn't be a problem.  The big plus is that it is standard,
allowing things
 > like this:
 >     gdalinfo -json | jq '{cornerCoordinates}' | ogr2ogr extent.shp
/vsistdin/
 > (jq is like sed for JSON data: see <http://stedolan.github.io/jq/>).
 > An added benefit is that the FeatureCollection also includes the bbox
 > information for easy access to the raster extent.
 > Best regards,
 > Homme
 > > Rob :)
 > > gdal-dev mailing list
 > > gdal-dev at lists.osgeo.org
 > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150330/ba462c28/attachment.html>
