[gdal-dev] building with libkea should use kea-config --hdfincludes
Vincent Schut schut at sarvision.nl
Tue Mar 31 02:16:08 PDT 2015
Saw that configure.in uses kea-config --cflags, which only results in the direct kea include dir being included. Here's a patch which uses --includes and --hdfincludes, which seems to work for me (need to run autogen.sh afterwards).
Vincent.
On 03/31/2015 10:55 AM, Vincent Schut wrote:
> Hi,
> I'm building gdal (svn trunk, updated this morning) on a debian (testing) server with libkea (own build). Libkea uses hdf5, and debian put's its hdf5 include files in /usr/include/hdf5/serial. Gdal build fails on libkea with:
> Entering directory '/usr/local/src/gdal/frmts/kea'
> /bin/bash /usr/local/src/gdal/libtool --mode=compile --tag=CXX g++ -I/usr/local/src/gdal/port -I/usr/local/src/gdal/gcore -I/usr/local/src/gdal/alg -I/usr/local/src/gdal/ogr -I/usr/local/src/gdal/ogr/ogrsf_frmts -g -O2  -Wall -Wunused-parameter  -I/usr/local/include   -DOGR_ENABLED -I/usr/local/src/gdal/port  -DGDAL_COMPILATION -c -o ../o/keaband.lo keaband.cpp
> libtool: compile:  g++ -I/usr/local/src/gdal/port -I/usr/local/src/gdal/gcore -I/usr/local/src/gdal/alg -I/usr/local/src/gdal/ogr -I/usr/local/src/gdal/ogr/ogrsf_frmts -g -O2 -Wall -Wunused-parameter -I/usr/local/include -DOGR_ENABLED -I/usr/local/src/gdal/port -DGDAL_COMPILATION -c keaband.cpp -fPIC -DPIC -o ../o/.libs/keaband.o
> In file included from keadataset.h:35:0,
>                  from keaband.h:35,
>                  from keaband.cpp:31:
> /usr/local/include/libkea/KEAImageIO.h:38:19: fatal error: H5Cpp.h: No such file or directory
>  #include "H5Cpp.h"
> compilation terminated.
> ../../GDALmake.opt:572: recipe for target '../o/keaband.lo' failed
> H5Cpp.h is in /usr/include/hdf5/serial, and that folder is given by kea-config --hdfincludes:
> Shouldnt gdal use that output from kea-config to pass to the compile command as -I (and maybe also kea-config --hdflibs)?
> Best,
> Vincent.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Index: configure.in
--- configure.in	(revision 28826)
+++ configure.in	(working copy)
@@ -1810,7 +1810,7 @@
   HAVE_KEA=yes
   KEA_LIB="`$KEA_CONFIG --libs`"
-  KEA_INC="`$KEA_CONFIG --cflags`"
+  KEA_INC="-I`$KEA_CONFIG --includes` -I`$KEA_CONFIG --hdfincludes`"
   AC_MSG_RESULT([yes])
 fi
