[gdal-dev] building with libkea should use kea-config --hdfincludes
Vincent Schut
schut at sarvision.nl
Tue Mar 31 02:30:06 PDT 2015
Thanks Even, builds fine now.
On 03/31/2015 11:13 AM, Even Rouault wrote:
> Le mardi 31 mars 2015 10:55:52, Vincent Schut a écrit :
>> Hi,
>> I'm building gdal (svn trunk, updated this morning) on a debian (testing)
>> server with libkea (own build). Libkea uses hdf5, and debian put's its
>> hdf5 include files in /usr/include/hdf5/serial. Gdal build fails on libkea
>> with:
>> Entering directory '/usr/local/src/gdal/frmts/kea'
>> /bin/bash /usr/local/src/gdal/libtool --mode=compile --tag=CXX g++
>> -I/usr/local/src/gdal/port -I/usr/local/src/gdal/gcore
>> -I/usr/local/src/gdal/alg -I/usr/local/src/gdal/ogr
>> -I/usr/local/src/gdal/ogr/ogrsf_frmts -g -O2 -Wall -Wunused-parameter
>> -I/usr/local/include -DOGR_ENABLED -I/usr/local/src/gdal/port
>> -DGDAL_COMPILATION -c -o ../o/keaband.lo keaband.cpp libtool: compile:
>> g++ -I/usr/local/src/gdal/port -I/usr/local/src/gdal/gcore
>> -DGDAL_COMPILATION -c keaband.cpp -fPIC -DPIC -o ../o/.libs/keaband.o In
>> file included from keadataset.h:35:0,
>> from keaband.h:35,
>> from keaband.cpp:31:
>> /usr/local/include/libkea/KEAImageIO.h:38:19: fatal error: H5Cpp.h: No such
>> file or directory #include "H5Cpp.h"
>> compilation terminated.
>> ../../GDALmake.opt:572: recipe for target '../o/keaband.lo' failed
>> H5Cpp.h is in /usr/include/hdf5/serial, and that folder is given by
>> kea-config --hdfincludes:
>> Shouldnt gdal use that output from kea-config to pass to the compile
>> command as -I (and maybe also kea-config --hdflibs)?
> Hi Vincent,
> makes sense. I've committed the addition of --hdflibs to KEA_LIB and --hdfcflags
> to KEA_INC
> Even
