[gdal-dev] Problems with MySQL queries in GDAL
Pavol Hnila
pavol.hnila at fu-berlin.de
Wed May 6 05:30:23 PDT 2015
Dear GDAL-developers,
I have noticed that the GDAL-Versions 1.11.2 used in QGIS 2.8 produce
complicated queries passed to MySQL that cause huge delays in QGIS when
working with spatial layers based on MySQL. It looks to me that GDAL
queries each time all tables in a database, even if only a single table
is requested. The older version 1.9.2 (used in QGIS 1.8) has not this
issue. I have described the problem in depth here:
http://gis.stackexchange.com/questions/135865/why-are-mysql-connections-extremely-slow-in-qgis-2-0-2-8-when-compared-to-qgi
The query logs of MySQL-Server can be seen here:
https://drive.google.com/folderview?id=0B1VM28puP8EPfmF2dGpjamVDWVZ6Vm1veHgtOElhY2lHb0ZTSlI1WXNuWWFvU3pRQmVLMTA&usp=sharing
Can someone have a look at it? I would greatly appreciate an explanation
of this GDAL behaviour and even more some fix or work-around. Can
someone replicate the problem or is there something specific about my
database design?
With best wishes,
Pavol
