[gdal-dev] python malloc error (gdal_array)
Ryan Grout
rgrout at continuum.io
Tue May 12 14:25:53 PDT 2015
I am building GDAL for OS X (along with the Python bindings).
To test that everything is working fine, run the following imports
import osgeo.ogr
import osgeo.osr
import osgeo.gdal
import osgeo.gdalconst
import osgeo.gdal_array
Each module was imported in a separate session of Python. After each
import, Python was closed by calling sys.exit() from within the
interpreter. When I import osgeo.gdal_array, and then I quit Python I
get the following error:
python(2690,0x7fff7db5d300) malloc: *** error for object
0x56415741e5894855: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
And Python crashes.
GDAL compiled with (and the resulting library is stripped with
--strip-unneeded)
bash configure \
--without-python \
--with-hdf5=$PREFIX \
--with-netcdf=$PREFIX \
--prefix=$PREFIX
make
make install
I then compile the python bindings with NumPy support from the GDAL
package on PyPI.
The problem only happens on OS X (I tested it on Linux, OS X, and Windows).
This leads me to believe that there may be a bug in gdal_array on OS X.
I'm not sure how to provide more info. Any thoughts? I'm surprised
that it is only happening on OS X.
