[gdal-dev] RE Python ogr GetFieldAsString problem
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu May 14 07:24:30 PDT 2015
I agree, no patch.
Actually the patch will be on my side. I might use python re, to replace
the comma by dot int he WFS response, for numeric field
If others are in the same situation, your suggestions are welcome
thanks
Even Rouault <even.rouault at spatialys.com>
2015-05-14 10:16
A
cc
gdal-dev at lists.osgeo.org
Objet
Re: [gdal-dev] RE Python ogr GetFieldAsString problem
Selon Steve.Toutant at inspq.qc.ca:
> Hi Even,
> I don't understand why GetFieldAsString() truncates the value....Should
it
> reads the value as it is?
To be pedantic, GetFieldAsString() does not truncate the value. The value
is
truncated before, in the GML reader, when inserting the value from the GML
as a
real value into the OGR real field.
> Is it because it also use a  GML reader?
The conversion from the XML content to the real value is done with a
function
(CPLAtof()) that assumes dot as the decimal character, which is the
correct
behaviour in that instance.
I guess you would have issues with most GML readers, that's why I'm a bit
hesitant into committing the patch.
> In this case I should probably use another tool than ogr to parse the
GML,
> something like preg_match in php....
> Thanks
> steve
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> 4e étage, Québec, Qc
> G1V 5B3
> 418 654-3010 poste 5428
> http://www.inspq.qc.ca
> http://www.monclimatmasante.qc.ca
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150514/7d10671a/attachment.html>
