[gdal-dev] ogr2ogr segfault
Ari Jolma
ari.jolma at gmail.com
Tue May 19 02:24:19 PDT 2015
19.05.2015, 12:05, Even Rouault kirjoitti:
> Paolo,
>> Hi all.
>> I'm consistently getting a segfault from:
>> ogr2ogr OUTPUTLAYER.shp strade.shp strade -dialect sqlite -sql "SELECT
>> ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade' "
>> Anything I can do for debugging?
> Running under gdb and displaying the stack trace.
ogr2ogr OUTPUTLAYER.shp strade.shp -dialect sqlite -sql "SELECT
ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade'"
ERROR 1: In ExecuteSQL(): sqlite3_prepare(SELECT
ST_Line_Interpolate_Point( geometry , 0.5 ),* FROM 'strade'):
no such function: ST_Line_Interpolate_Point
I have both SQLite and SpatiaLite support on. What's going on?
Ari
>> Debian Sid, might be a platform specific issue?
>> https://bugs.debian.org/785091
> I've seen recently a similar discussion on spatialite mailing list I think. If
> upgrading from spatialite 4.something to 4.1.2 or later, GDAL should also be
> recompiled so as to benefit from the spatialite_init_ex() functions
> I don't recall the details but I somehow remember that one of the intermediate
> spatialite versions had an issue in its termination routine freeing the global
> GEOS context. I don't have any more problems with latest versions. But the
> debian ticket you mention seemed to be about a problem that arose with proj4
> update. Hum...
> Even
