[gdal-dev] RFC 58: Removing Dataset Nodata Value
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue May 19 06:43:38 PDT 2015
Ivan Lucena <lucena_ivan <at> hotmail.com> writes:
> Would that be feasible to accept the option "-a_nodata NO" on GDAL command
lines, to indicate that NoData should not pass from the input to the output
dataset?
Would it be something different than "-a_nodata none"?
-a_nodata value:
    Assign a specified nodata value to output bands. Starting with GDAL
1.8.0, can be set to none to avoid setting a nodata value to the output file
if one exists for the source file. Note that, if the input dataset has a
nodata value, this does not cause pixel values that are equal to that nodata
value to be changed to the value specified with this option.
-Jukka Rahkonen-
