[gdal-dev] RFC 58: Removing Dataset Nodata Value
Ivan Lucena
lucena_ivan at hotmail.com
Tue May 19 07:06:59 PDT 2015
Jukka/Even,
Yes, you guy are right. The "-a_nodata none" will help but I still need to implement a value range check on my CreateCopy anyway. So users don't need to run gdal_translate again after they find the problem or use "-a_nodata none" all the time (in a script for example) and miss the good ones.
Thanks.
> To: gdal-dev at lists.osgeo.org
> From: jukka.rahkonen at maanmittauslaitos.fi
> Date: Tue, 19 May 2015 13:43:38 +0000
> Subject: Re: [gdal-dev] RFC 58: Removing Dataset Nodata Value
> Ivan Lucena <lucena_ivan <at> hotmail.com> writes:
> > Would that be feasible to accept the option "-a_nodata NO" on GDAL command
> lines, to indicate that NoData should not pass from the input to the output
> dataset?
> Would it be something different than "-a_nodata none"?
> -a_nodata value:
> Assign a specified nodata value to output bands. Starting with GDAL
> 1.8.0, can be set to none to avoid setting a nodata value to the output file
> if one exists for the source file. Note that, if the input dataset has a
> nodata value, this does not cause pixel values that are equal to that nodata
> value to be changed to the value specified with this option.
> -Jukka Rahkonen-
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150519/f01667a5/attachment.html>
