[gdal-dev] RFC 58: Removing Dataset Nodata Value
Even Rouault
even.rouault at spatialys.com
Tue May 19 07:10:38 PDT 2015
Le mardi 19 mai 2015 16:06:59, Ivan Lucena a écrit :
> Jukka/Even,
> Yes, you guy are right. The "-a_nodata none" will help but I still need to
> implement a value range check on my CreateCopy anyway. So users don't need
> to run gdal_translate again after they find the problem or use "-a_nodata
> none" all the time (in a script for example) and miss the good ones.
I'm wondering if it might not make more sense to modify the input driver(s) to
not report out-of-range nodata values ? I fail to see a reason to report an
out-of-range nodata value.
> Thanks.
> > To: gdal-dev at lists.osgeo.org
> > From: jukka.rahkonen at maanmittauslaitos.fi
> > Date: Tue, 19 May 2015 13:43:38 +0000
> > Subject: Re: [gdal-dev] RFC 58: Removing Dataset Nodata Value
> > Ivan Lucena <lucena_ivan <at> hotmail.com> writes:
> > > Would that be feasible to accept the option "-a_nodata NO" on GDAL
> > > command
> > lines, to indicate that NoData should not pass from the input to the
> > output dataset?
> > Would it be something different than "-a_nodata none"?
> > -a_nodata value:
> > Assign a specified nodata value to output bands. Starting with GDAL
> > 1.8.0, can be set to none to avoid setting a nodata value to the output
> > file if one exists for the source file. Note that, if the input dataset
> > has a nodata value, this does not cause pixel values that are equal to
> > that nodata value to be changed to the value specified with this option.
> > -Jukka Rahkonen-
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
