[gdal-dev] gdalwarp problems with MODIS L1B
Michael Sumner mdsumner at gmail.com
Wed May 20 01:33:33 PDT 2015
Hello, I'm having problems with gdalwarp-ing a MODIS L1B calibrated
radiance dataset.
This file contains 31 SDS subdatasets, the first two here are Latitude and
Longitude arrays and the third is the reflectance data EV_1KM_RefSB. The
geolocation arrays have a pixel and line for every fifth pixel/line in the
data
MOD021KM.A2012062.0455.006.2014220083128.hdf
SUBDATASET_20_NAME=HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":0
SUBDATASET_20_DESC=[406x271] Latitude (32-bit floating-point)
SUBDATASET_21_NAME=HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":1
SUBDATASET_21_DESC=[406x271] Longitude (32-bit floating-point)
SUBDATASET_22_NAME=HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":2
SUBDATASET_22_DESC=[15x2030x1354] EV_1KM_RefSB (16-bit unsigned integer)
By my reading of https://trac.osgeo.org/gdal/wiki/rfc4_geolocate that means
the Geolocation tag from gdalinfo should have a PIXEL_STEP and LINE_STEP of
5, and if I do this I get a much better result but it's still not right.
I've put a jpeg image of the result, with the coastline mapped and not
lining up, here:
http://staff.acecrc.org.au/~mdsumner/mod1.jpg
If I understand correctly, gdalwarp should be able to georeference this
with a simple call, optionally with tr, te, and t_srs values
gdalwarp infile out.tif
The t_srs I use is '+proj=laea +lon_0=60 +lat_0=-70 +ellps=WG84'.
 Here's the gdalinfo output for the EV_1KM_RefSB subdataset for the
relevant section:
gdalinfo HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":2
|  grep 'Geolocation:' -A 10
Geolocation:
  LINE_OFFSET=0
  LINE_STEP=1
  PIXEL_OFFSET=0
  PIXEL_STEP=1
  SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
  X_BAND=1
X_DATASET=HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":1
  Y_BAND=1
Y_DATASET=HDF4_SDS:UNKNOWN:"MOD021KM.A2012062.0455.006.2014220083128.hdf":0
Corner Coordinates:
I get this file originally from here (136 Mb):
ftp://ladsweb.nascom.nasa.gov/allData/6/MOD021KM/2012/062/MOD021KM.A2012062.0455.006.2014220083128.hdf
I see this in 1.11.1 and 2.0.0beta1.
I have also attached the gdalinfo output in full here:
http://staff.acecrc.org.au/~mdsumner/gdalinfo_EV_1KM_RefSB.txt
cheers, Mike.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150520/b6d6116f/attachment-0001.html>
