[gdal-dev] JP2OpenJPEG Driver Reads 4th Band of NITF as Alpha
Claire Porter claire.porter at gmail.com
Wed May 20 07:29:10 PDT 2015
Even and James,
Thanks for the suggestions.  Even's advice about converting first to a VRT,
modifying the Color Interpretation of the 4th band, and then using gdalwarp
worked perfectly.
In terms of the larger picture, is this a a bug I should report to OpenJPEG
or is it something best handled here?  Or, alternatively, is the workaround
good enough that it's not worth following up on?
Thanks again,
Claire
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150520/4eb3bc31/attachment.html>
