[gdal-dev] JP2OpenJPEG Driver Reads 4th Band of NITF as Alpha
Claire Porter
claire.porter at gmail.com
Wed May 20 07:33:14 PDT 2015
Even,
Sorry, I did not read your email closely enough. I see it has been fixed.
Thanks,
Claire
On Wed, May 20, 2015 at 9:29 AM, Claire Porter <claire.porter at gmail.com>
wrote:
> Even and James,
> Thanks for the suggestions. Even's advice about converting first to a
> VRT, modifying the Color Interpretation of the 4th band, and then using
> gdalwarp worked perfectly.
> In terms of the larger picture, is this a a bug I should report to
> OpenJPEG or is it something best handled here? Or, alternatively, is the
> workaround good enough that it's not worth following up on?
> Thanks again,
> Claire
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150520/3980b742/attachment.html>
