[gdal-dev] GIntBig in the bindings
Ari Jolma
ari.jolma at gmail.com
Fri May 22 01:46:05 PDT 2015
22.05.2015, 11:38, Ari Jolma kirjoitti:
> It seems that there are quite a few interface methods with two
> versions where the only difference is whether GIntBig is used or not.
> Also some methods do not have GIntBig when they actually should use it
> since it is in the GDAL API.
> I found out that at least in Swig Perl default typemaps have long long
> and unsigned long long. Thus using GIntBig should mostly be just the
> case of saying
> %apply (long long) { GIntBig };
> At least Python, Java and CSharp seem to have default typemaps for
> long long and unsigned long long.
> However, what GIntBig really is, is a configure time decision. That
> should be somehow propagated to the bindings.
I must also say that we're loosing (have lost?) the benefit of having a
single set of "language independent" interface files because of all the
#ifdefs in them. It might be easier to have only separate sets and then
manually copy paste and edit when new things are added.
Ari
> Ari
