[gdal-dev] aclocal.m4 checked in
Even Rouault
even.rouault at spatialys.com
Sun Nov 1 08:55:24 PST 2015
Le dimanche 01 novembre 2015 17:47:12, Greg Troxel a écrit :
> Running 'svn status' after building. I see aclocal.m4 is modified. The
> changes are small, but it seems that generated files shouldn't be
> checked in, and configure isn't, so I would suggest svn rm aclocal.m4.
> However, it was updated recently so perhaps this is intended.
Did you run autogen.sh or aclocal ? If so, that's not necessary since the
generated files are put in svn, for the worse or the better.
> diff for amusement:
> Index: aclocal.m4
> --- aclocal.m4 (revision 31282)
> +++ aclocal.m4 (working copy)
> @@ -1,7 +1,7 @@
> -# generated automatically by aclocal 1.11 -*- Autoconf -*-
> +# generated automatically by aclocal 1.15 -*- Autoconf -*-
> -# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
> -# 2005, 2006, 2007, 2008, 2009 Free Software Foundation, Inc.
> +# Copyright (C) 1996-2014 Free Software Foundation, Inc.
> # This file is free software; the Free Software Foundation
> # gives unlimited permission to copy and/or distribute it,
> # with or without modifications, as long as this notice is preserved.
> @@ -11,6 +11,7 @@
> # even the implied warranty of MERCHANTABILITY or FITNESS FOR A
> # PARTICULAR PURPOSE.
> +m4_ifndef([AC_CONFIG_MACRO_DIRS], [m4_defun([_AM_CONFIG_MACRO_DIRS],
> [])m4_defun([AC_CONFIG_MACRO_DIRS], [_AM_CONFIG_MACRO_DIRS($@)])])
> m4_include([m4/acinclude.m4])
> m4_include([m4/ax_cflags_warn_all.m4])
> m4_include([m4/ax_check_compile_flag.m4])
http://www.spatialys.com
