[gdal-dev] Unable to compile Gdal under Cygwin
Even Rouault
even.rouault at spatialys.com
Mon Nov 2 02:14:37 PST 2015
Le lundi 02 novembre 2015 10:56:40, Dr Rainer Woitok a écrit :
> Even,
> On Sunday, 2015-11-01 16:37:42 +0100, you wrote:
> > As I said before, I'd rather suggest you use --with-static-proj4 instead,
> > which contrary to what its name suggest, does classic library linking
> > (dynamic or static depending on what is available)
> Am I understanding that correctly: I just should run
> configure ... --with-static-proj4=/home/Rainer/.../cygproj-10.dll
No, you should point to the directory where "make install" has put the files,
ie the one that has include and lib subdirectories
> and then the wrong LIBNAME in file "ogr/ogrct.cpp" just wouldn't matter
> anymore? In that case I think an update to "configure --help" would be
> in order, pointing out that the library type specified here determines
> dynamic or static linking. And perhaps the "-static" sould be removed
> from this option's name altogether. I'll give it a try later with the
> next update of Gdal, but for the time being I'll use my current version.
> > Yes parallel make in autotest is unreliable. Was mostly an experiment but
> > some tests have interferences.
> By the way, why isn't there a "test" target in the toplevel makefile?
> Why do people have to hunt for it?
I don't know
> You didn't comment on the tests that failed for my installation. Should
> I worry?
Difficult to say without further investigation. Some tests might be sensitive to
particular version of third party libraries, compiler version & flags, etc...
> Sincerely,
> Rainer
> | Rainer M Woitok | Phone : (+49 60 93) 487 95 95 |
> | Kolpingstraße 3 | Mobile: (+49 172) 813 6 831 |
> | D-63846 Laufach | Mail : Rainer.Woitok at Gmail.Com |
> | Germany | |
http://www.spatialys.com
