[gdal-dev] Antw: Re: Issues with GDAL compilation
Matthias Benedikt
matthias.benedikt at boku.ac.at
Wed Nov 4 02:21:31 PST 2015
Perfect!
Replacing
#if defined(__GNUC__) && defined(__x86_64__)
with
#if 0
did the trick, thanks a million!
>>> Even Rouault <even.rouault at spatialys.com> 04.11.2015 11:13 >>>
Matthias,
Plese remind to keep the list CC'ed.
> I tried also with the latest version and --without-avx, here's the
> result:
> GDAL is now configured for x86_64-unknown-linux-gnu
> Installation directory: /path/to/src/gdal-2.0.1/build
> C compiler: icc -g -Wall
> C++ compiler: icpc -g -O2
> LIBTOOL support: yes
> LIBZ support: external
> LIBLZMA support: no
> GRASS support: no
> CFITSIO support: no
> PCRaster support: internal
> LIBPNG support: internal
> DDS support: no
> GTA support: no
> LIBTIFF support: internal (BigTIFF=yes)
> LIBGEOTIFF support: internal
> LIBJPEG support: internal
> 12 bit JPEG: yes
> 12 bit JPEG-in-TIFF: yes
> LIBGIF support: internal
> OGDI support: no
> HDF4 support: no
> HDF5 support: yes
> Kea support: no
> NetCDF support: yes
> Kakadu support: no
> JasPer support: yes (GeoJP2=no)
> OpenJPEG support: no
> ECW support: no
> MrSID support: no
> MrSID/MG4 Lidar support: no
> MSG support: no
> GRIB support: yes
> EPSILON support: no
> WebP support: no
> cURL support (wms/wcs/...):yes
> PostgreSQL support: no
> MySQL support: no
> Ingres support: no
> Xerces-C support: no
> NAS support: no
> Expat support: yes
> libxml2 support: yes
> Google libkml support: no
> ODBC support: no
> PGeo support: no
> FGDB support: no
> MDB support: no
> PCIDSK support: internal
> OCI support: no
> GEORASTER support: no
> SDE support: no
> Rasdaman support: no
> DODS support: no
> SQLite support: yes
> PCRE support: no
> SpatiaLite support: no
> DWGdirect support no
> INFORMIX DataBlade support:no
> GEOS support: yes
> Poppler support: no
> Podofo support: no
> OpenCL support: no
> Armadillo support: no
> FreeXL support: no
> SOSI support: no
> SWIG Bindings: no
> Statically link PROJ.4: yes
> enable OGR building: yes
> enable pthread support: yes
> enable POSIX iconv support:yes
> hide internal symbols: no
> make -j8 went through without errors, but make install does that
> again:
> [132 at l32 gdal-2.0.1]$ make install
> (cd port; make)
> make[1]: Entering directory `/path/to/src/gdal-2.0.1/port'
> make[1]: Nothing to be done for `default'.
> make[1]: Leaving directory `/path/to/src/gdal-2.0.1/port'
> (cd gcore; make)
> make[1]: Entering directory `/path/to/src/gdal-2.0.1/gcore'
> make -C mdreader
> make[2]: Entering directory `/path/to/src/gdal-2.0.1/gcore/mdreader'
> make[2]: Nothing to be done for `default'.
> make[2]: Leaving directory `/path/to/src/gdal-2.0.1/gcore/mdreader'
> make[1]: Leaving directory `/path/to/src/gdal-2.0.1/gcore'
> (cd alg; make)
> make[1]: Entering directory `/path/to/src/gdal-2.0.1/alg'
> /bin/sh /path/to/src/gdal-2.0.1/libtool --mode=compile --tag=CXX icpc
> -I/path/to/src/gdal-2.0.1/port -I/path/to/src/gdal-2.0.1/gcore
> -I/path/to/src/gdal-2.0.1/alg -I/path/to/src/gdal-2.0.1/ogr
> -I/path/to/src/gdal-2.0.1/ogr/ogrsf_frmts -g -O2 -Wall -DHAVE_GEOS=1
> -I/path/to/src/geos-3.4.2/build/include -DHAVE_SSE_AT_COMPILE_TIME
> -DOGR_ENABLED -I/path/to/src/gdal-2.0.1/port
> -I/path/to/src/netcdf-4.3.3.1/build/include -DGDAL_COMPILATION -c -o
> thinplatespline.lo thinplatespline.cpp
> libtool: compile: icpc -I/path/to/src/gdal-2.0.1/port
> -I/path/to/src/gdal-2.0.1/gcore -I/path/to/src/gdal-2.0.1/alg
> -I/path/to/src/gdal-2.0.1/ogr -I/path/to/src/gdal-2.0.1/ogr/ogrsf_frmts
> -g -O2 -Wall -DHAVE_GEOS=1 -I/path/to/src/geos-3.4.2/build/include
> -DHAVE_SSE_AT_COMPILE_TIME -DOGR_ENABLED -I/path/to/src/gdal-2.0.1/port
> thinplatespline.cpp -fPIC -DPIC -o .libs/thinplatespline.o
> ": internal error: 010101_3007
> compilation aborted for thinplatespline.cpp (code 4)
> make[1]: *** [thinplatespline.lo] Error 1
> make[1]: Leaving directory `/path/to/src/gdal-2.0.1/alg'
> make: *** [core-target] Error 2
> Any other ideas?
Perhaps... Apart from cursing the buggy compiler (if it is an uptodate version
of it, you might want to report to the vendor as it is a shame it aborts on
this), you might try to replace the following line of alg/thinplatespline.cpp,
aroud line 125
by
#if 0
This will disable an optimization, which is the trickiest part of that file.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151104/0451bc07/attachment-0001.html>
