[gdal-dev] Antw: Re: Issues with GDAL compilation
Even Rouault
even.rouault at spatialys.com
Wed Nov 4 04:36:35 PST 2015
Le mercredi 04 novembre 2015 11:21:31, Matthias Benedikt a écrit :
> Perfect!
> Replacing
> #if defined(__GNUC__) && defined(__x86_64__)
> with
> #if 0
> did the trick, thanks a million!
I don't know if you're a C/C+ developer, but if so, perhaps you could provide
a patch to detect this compiler ?
I guess this must be something around
#ifdef __INTEL_COMPILER
but that's maybe too extreme as I hope that it is just that you use an
outdated version of it and that newer versions work better.
So perhaps something like
#if (defined(__INTEL_COMPILER) && __INTEL_COMPILER <= buggy_version_number )
assuming blindlessly that the value of __INTEL_COMPILER reflects a version
number.
> >>> Even Rouault <even.rouault at spatialys.com> 04.11.2015 11:13 >>>
> Matthias,
> Plese remind to keep the list CC'ed.
> > I tried also with the latest version and --without-avx, here's the
> > result:
> > GDAL is now configured for x86_64-unknown-linux-gnu
> > Installation directory: /path/to/src/gdal-2.0.1/build
> > C compiler: icc -g -Wall
> > C++ compiler: icpc -g -O2
> > LIBTOOL support: yes
> > LIBZ support: external
> > LIBLZMA support: no
> > GRASS support: no
> > CFITSIO support: no
> > PCRaster support: internal
> > LIBPNG support: internal
> > DDS support: no
> > GTA support: no
> > LIBTIFF support: internal (BigTIFF=yes)
> > LIBGEOTIFF support: internal
> > LIBJPEG support: internal
> > 12 bit JPEG: yes
> > 12 bit JPEG-in-TIFF: yes
> > LIBGIF support: internal
> > OGDI support: no
> > HDF4 support: no
> > HDF5 support: yes
> > Kea support: no
> > NetCDF support: yes
> > Kakadu support: no
> > JasPer support: yes (GeoJP2=no)
> > OpenJPEG support: no
> > ECW support: no
> > MrSID support: no
> > MrSID/MG4 Lidar support: no
> > MSG support: no
> > GRIB support: yes
> > EPSILON support: no
> > WebP support: no
> > cURL support (wms/wcs/...):yes
> > PostgreSQL support: no
> > MySQL support: no
> > Ingres support: no
> > Xerces-C support: no
> > NAS support: no
> > Expat support: yes
> > libxml2 support: yes
> > Google libkml support: no
> > ODBC support: no
> > PGeo support: no
> > FGDB support: no
> > MDB support: no
> > PCIDSK support: internal
> > OCI support: no
> > GEORASTER support: no
> > SDE support: no
> > Rasdaman support: no
> > DODS support: no
> > SQLite support: yes
> > PCRE support: no
> > SpatiaLite support: no
> > DWGdirect support no
> > INFORMIX DataBlade support:no
> > GEOS support: yes
> > Poppler support: no
> > Podofo support: no
> > OpenCL support: no
> > Armadillo support: no
> > FreeXL support: no
> > SOSI support: no
> > SWIG Bindings: no
> > Statically link PROJ.4: yes
> > enable OGR building: yes
> > enable pthread support: yes
> > enable POSIX iconv support:yes
> > hide internal symbols: no
> > make -j8 went through without errors, but make install does that
> > again:
> > [132 at l32 gdal-2.0.1]$ make install
> > (cd port; make)
> > make[1]: Entering directory `/path/to/src/gdal-2.0.1/port'
> > make[1]: Nothing to be done for `default'.
> > make[1]: Leaving directory `/path/to/src/gdal-2.0.1/port'
> > (cd gcore; make)
> > make[1]: Entering directory `/path/to/src/gdal-2.0.1/gcore'
> > make -C mdreader
> > make[2]: Entering directory `/path/to/src/gdal-2.0.1/gcore/mdreader'
> > make[2]: Nothing to be done for `default'.
> > make[2]: Leaving directory `/path/to/src/gdal-2.0.1/gcore/mdreader'
> > make[1]: Leaving directory `/path/to/src/gdal-2.0.1/gcore'
> > (cd alg; make)
> > make[1]: Entering directory `/path/to/src/gdal-2.0.1/alg'
> > /bin/sh /path/to/src/gdal-2.0.1/libtool --mode=compile --tag=CXX icpc
> > -I/path/to/src/gdal-2.0.1/port -I/path/to/src/gdal-2.0.1/gcore
> > -I/path/to/src/gdal-2.0.1/alg -I/path/to/src/gdal-2.0.1/ogr
> > -I/path/to/src/gdal-2.0.1/ogr/ogrsf_frmts -g -O2 -Wall -DHAVE_GEOS=1
> > -I/path/to/src/geos-3.4.2/build/include -DHAVE_SSE_AT_COMPILE_TIME
> > -DOGR_ENABLED -I/path/to/src/gdal-2.0.1/port
> > -I/path/to/src/netcdf-4.3.3.1/build/include -DGDAL_COMPILATION -c -o
> > thinplatespline.lo thinplatespline.cpp
> > libtool: compile: icpc -I/path/to/src/gdal-2.0.1/port
> > -I/path/to/src/gdal-2.0.1/gcore -I/path/to/src/gdal-2.0.1/alg
> > -I/path/to/src/gdal-2.0.1/ogr -I/path/to/src/gdal-2.0.1/ogr/ogrsf_frmts
> > -g -O2 -Wall -DHAVE_GEOS=1 -I/path/to/src/geos-3.4.2/build/include
> > -DHAVE_SSE_AT_COMPILE_TIME -DOGR_ENABLED -I/path/to/src/gdal-2.0.1/port
> > thinplatespline.cpp -fPIC -DPIC -o .libs/thinplatespline.o
> > ": internal error: 010101_3007
> > compilation aborted for thinplatespline.cpp (code 4)
> > make[1]: *** [thinplatespline.lo] Error 1
> > make[1]: Leaving directory `/path/to/src/gdal-2.0.1/alg'
> > make: *** [core-target] Error 2
> > Any other ideas?
> Perhaps... Apart from cursing the buggy compiler (if it is an uptodate
> version of it, you might want to report to the vendor as it is a shame it
> aborts on this), you might try to replace the following line of
> alg/thinplatespline.cpp, aroud line 125
> by
> #if 0
> This will disable an optimization, which is the trickiest part of that
> file.
http://www.spatialys.com
