[gdal-dev] gdalwarp
MUTLU OZDOGAN ozdogan at wisc.edu
Wed Nov 4 11:16:06 PST 2015
Dear List
I have a compressed 4-band geotiff image with the 4th band being the Alpha channel.  When I reproject this image to any other projection using gdalwarp or cut a a small window out of it using gdal_translate, all pixel values become 0 although in the original image they are not zeros.  I think this is because the alpha channel is being interpreted as a mask band - how do I turn this off?  I just want to be able to reproject the image and retain pixel values of all 4 bands (including the alpha band) in the new reprojected file.
Thank you.
Mutlu..
Mutlu Ozdogan, Ph.D.
Associate Professor
Department of Forest and Wildlife Ecology &
Nelson Institute for Environmental Studies
t: (608) 262-0873
e: ozdogan at wisc.edu<mailto:ozdogan at wisc.edu>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151104/a3f9ae0a/attachment.html>
