[gdal-dev] Geometry not displayed with Filegeodb on GDAL 2.0.1
Gane R gane.prog at gmail.com
Mon Nov 23 08:29:41 PST 2015
Hi all,
I tried to build *GDAL 2.0.1* with *filegeodb* support with *proj4* as
static lib on *Linux*. I am able to use the API to get the field data from
Filegeodb but I am *not able to get the geometry*.  I have configured as
./configure --with-fgdb=/fgdblib --with-static-proj4=/usr/local/
--with-xml2=no --with-sqlite3=no --with-curl=no --with-expat=no
I am wondering what went wrong. But ogrinfo shows the values of the same
filegeodb file.
Thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151123/40fa0ff5/attachment.html>
