[gdal-dev] Unable to compile Gdal under Cygwin
Even Rouault
even.rouault at spatialys.com
Sat Oct 10 07:36:24 PDT 2015
Le samedi 10 octobre 2015 16:31:50, Dr Rainer Woitok a écrit :
> Even,
> On Friday, 2015-10-09 19:10:53 +0200, you wrote:
> > It seems the error is linked to the Python GNM module when GDAL is not
> > configured --with-gnm.
> Ok, I thought, if the missing "--with-gnm" option spoils my compilation,
> I could as well add it. And lo and behold! the compilation succeeded.
I should have suggested the workaround, sorry.
I've created https://trac.osgeo.org/gdal/ticket/6144 to track the issue.
> But what, apart from a successful compilation, does this option really
> buy me? The command "configure --help" only tells me
> --with-gnm Build GNM into shared library
> which doesn't really convey any information.
See https://trac.osgeo.org/gdal/wiki/rfc48_geographical_networks_support
> Sincerely,
> Rainer
> | Rainer M Woitok | Phone : (+49 60 93) 487 95 95 |
> | Kolpingstraße 3 | Mobile: (+49 172) 813 6 831 |
> | D-63846 Laufach | Mail : Rainer.Woitok at Gmail.Com |
> | Germany | |
http://www.spatialys.com
