[gdal-dev] Unable to compile Gdal under Cygwin
Even Rouault
even.rouault at spatialys.com
Sun Oct 11 07:57:05 PDT 2015
Le dimanche 11 octobre 2015 16:17:28, Dr Rainer Woitok a écrit :
> Hi,
> On Saturday, 2015-10-10 16:31:50 +0200, I myself wrote:
> > And lo and behold! the compilation succeeded.
> Now on to testing: plenty of tests failing due to
> ERROR 6: Unable to load PROJ.4 library (cygproj-0.dll)
> Well, the real PROJ.4 library is meanwhile named "cygproj-10.dll" and
> resides in a directory mentioned in environment variable "PATH". Where
> does the name "cygproj-0.dll" come from? Can I do something about that
> (other than linking statically via "--with-static-proj4=...")?
> Somehow I don't quite like the idea of renaming my PROJ.4 library to
> what Gdal currently thinks is the right name :-(
Ah, yes I guess it comes from latest proj version where the soname was bumped.
Well you can safely rename/copy cygproj-10.dll as cygproj-0.dll to please what
is currently hardcoded in ogr/ogrct.cpp
--with-static-proj4 is probably the cleanest alternative rather than dynamic
loading.
> Sincerely,
> Rainer
> | Rainer M Woitok | Phone : (+49 60 93) 487 95 95 |
> | Kolpingstraße 3 | Mobile: (+49 172) 813 6 831 |
> | D-63846 Laufach | Mail : Rainer.Woitok at Gmail.Com |
> | Germany | |
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
